View unanswered posts | View active topics It is currently Fri 15 Dec, 2017 4:29 pm
 hard to start 350
Post hard to start 350
Been reading a bit that the 350exc sometimes can be hard to start cold . same happened to mine to cut it short i"d over oiled the air cleaner no more than i"d oiled my old wr "s but it must be a lot more sensitive . fuel injection dontknow but anyway if yours is doing it and you oil the air cleaner try that it may fix it !!!!!!!cheers sorry posted twice BangHead
Sun 20 May, 2012 3:54 pm
Post Re: hard to start 350
What sort of filter oil do you use Zombie? Not that mines injected I find the Silkolene filer oil, and it seems the Motorex stuff is similar, to be very good. Goes in like water and tacks off very quickly once the carrier has evaporated.
Still I leave it on a clean rag overnight or as long as possible to make sure it's totally gone. I had a similar problem with other thicker filter oils especially at this time of the year when it's cold. You end up trying to cover the filter and putting way to much on.
Just a thought!
Tef.
Simon. 09 530exc
Currently suffering from PMS. Parked Motorcycle Syndrome :( .
Sun 20 May, 2012 4:20 pm
I use Motul oil for the cleaner but i apply it with a paint brush instead of soaking it in. I find that it doesn't clog it up as much now. Cheers :D
Sun 20 May, 2012 5:09 pm
geez mate.....its not an oil painting binkybaby
________________________________
05 CRF450X......
97 XR400R
94 XR250R
92 ZZR250
Fri 25 May, 2012 4:54 pm
up ya bootyshake
Fri 25 May, 2012 5:28 pm
