View unanswered posts | View active topics It is currently Sat 16 Dec, 2017 11:34 am
Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 new yamaha 450 f
Post new yamaha 450 f
Was up at kennilworth on sat got talkin to a guy on a new 450 his opinion so far front end is a vast improvement on the older models you can steer it into corners and it sticks (his words ) But one problem is it wont start with the button a lot of the times (maybe only his bike) not a problem with the model hav"nt heard yet. yamaha were a bit of problem in that area but .the other thing was the hot start there is no lever only a push pull under the tank hard to get to .thought that was weird dontknow .other than that he was more than happy with it . forgot to ask him about fuel economy though BangHead
Mon 09 Apr, 2012 3:40 pm
Post Re: new yamaha 450 f
fuel apparently no good on them. ( from what i heard )
the probem with the wr is they get stuck on top dead. and you need to use the kicker or roll it in gear to bring it of top dead centre.
mind improved after 2-3000 km when it lossend up a little
Mon 09 Apr, 2012 3:48 pm
what it look like no Pic ??
sounds bit like my bike after today broken hot start lever bent gear lever but went around corners great :P
Mon 09 Apr, 2012 3:49 pm
Sorry no camera on me at the time BangHead . why they never put the yz motor in it beats the s@$t out of me they"ve also got a thermostat lookin thing right up against the radiator looks like it"ll wear through it in no time . Looks like a lot of the design was an after thought ! dontknow
Mon 09 Apr, 2012 5:24 pm
you dont need a hot start on injected bikes the button under the tanks are idle speed and a cold start if u need one but i highly doubt you will .
the bike wont start if u try and it does not fire wait a second or two and try again the ecu resets i believe
Mon 09 Apr, 2012 7:12 pm
I read in a mag the new 2012 450f get's 80ks then its 20k's on reserve on the stock tank.... They do look nice hello2
Sun 24 Jun, 2012 9:51 pm
If weight is an issue, based on what I saw last weekend there is a LOT of weight to be saved ditching the electric starter and associated parts all together. The bike was starting 1st or failing that 2nd kick EVERY time.
Sun 24 Jun, 2012 10:57 pm
Maybe the writer can push you back too the cars when it runs out. :D :D
Mate has one and we did Woodenbong ride mth ago did 2 loops (without topping tank up) on the Sat which were about 45klms.....had too push him the last few hundred meters back too camp sign10 .....still tight so may get a bit more after it loosens up.
Mon 25 Jun, 2012 9:09 am
What no 45ks? thats all...... man that is effing bad. I was one signature away from buying/owning this year's 450f... for the riding i do i wouldn't even be able to get half way to the next town from mt isa (cloncurry about 120k's nearest fuel station from home).
Wed 27 Jun, 2012 8:22 pm
Mate has one and we did Woodenbong ride mth ago did 2 loops (without topping tank up) on the Sat which were about 45klms.....had too push him the last few hundred meters back too camp sign10 .....still tight so may get a bit more after it loosens up.[/quote]
45+44.7klms=89.7klms.....................................still not 100 but better than the earlier model dontknow (was only 2nd ride.)
Wed 27 Jun, 2012 10:20 pm
If jetted correctly some 450Hams can do 120klms
Thu 28 Jun, 2012 8:44 am
I wonder if any of the mileage issue is with smooth use of the throttle vs folks snapping it on and off and how much is single track style riding versus going 100km/hr + on open trails, fire roads etc. It would be a reasonably long day riding tight ST over 100km.
Thu 28 Jun, 2012 9:17 am
with the jetting i had before the build on a STD tank id go 110km before reserve
would go 160-180 with 13.5 tank i have now.
Thu 28 Jun, 2012 1:48 pm
