View unanswered posts | View active topics It is currently Wed 21 Feb, 2018 5:22 am
This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Helmet Lights 4 sale
Post Helmet Lights 4 sale
$60 and these work great icon_thumright Pm me a must have for night riding
Can be used as Headlamp or Bicycle Light
· Model of LED: CREE XM-L T6 LED
· Output bright can come to max 1600 lumens [lm]
· Ergonomic designed head band with ABS enforce plate. Adjustable light angle
· Come with
· Internal wiring applies the high efficient booster circuit; working voltage is wide and can utilize the batteries in the largest extent.
· Waterproofing design
· Aluminium alloy casing
· Aluminium alloy reflector
· 3 switch Mode: Strong Brightness / Normal Brightness / Flashing
· 100v-240v Australia Standard Battery Charger , no need adaptor
· Power supply: 8.4V/6400mAh battery
· Dimension : 44mm
· Weight : 158g
Mon 26 Mar, 2012 7:43 pm
