View unanswered posts | View active topics It is currently Tue 20 Feb, 2018 7:47 pm
Reply to topic  [ 2 posts ]
 SD Card Recall / replacement - Go Pro HD
Post SD Card Recall / replacement - Go Pro HD
Since picking up on the card issues & letting Go Pro know about the inconsistencies & that some sellers were supplying other than the recommended cards, I've invested about $1000 in different brands, sizes, class of cards so I could test them myself.
Go Pro are following up manufacturer specs, there are some problems with them not meeting the requirements of the camera host reader.
I have taken delivery of 300 Kingston Class 4 cards today, they are the only ones that are 100% consistent across 5 cameras tested.
I recieved the 4gb today with 8,16 & 32 still on order.
If anyone has problems with the cards supplied (other than Kingston), pls let me know & I'll send you a Kingston 4gb immediately, if you took the 8gb deal when buying the cam, you will still get the 4gb now & when the others arrive we'll send you one also.
Rated a close 2nd is DSE micro card,but out of 5 cameras, 3 were 100% & 2 had problems on certain settings,the other problem is Dick Smith cards could be anything & aren't well priced.
replacement offer only valid to purchases from GETONIT Performance Sports Aust
Tue 29 Dec, 2009 1:47 pm
Post Re: SD Card Recall / replacement - Go Pro HD
Best choice of card IMO & tested as accurate
Obviously bigger will be good, but this way it's 1 card per battery pack, simple
Kingston 16gb Class 4
All settings recorded fine & battery ran out before card full
R5 - 2.5hrs with 1 gb remaining on card (fully charged to depleted battery) on Highest HD setting.
Tue 29 Dec, 2009 3:39 pm
