View unanswered posts | View active topics It is currently Mon 21 May, 2018 10:56 am
 Drift Innovations - HD170 Stealth (SD Card not reading)
Post Drift Innovations - HD170 Stealth (SD Card not reading)
Hi All,
My HD170 stealth SD reader does not register an SD card.
I have tried the following to resolve the issue though nothing has worked.
1. Check the card was empty and tried again
2. Tried another SD card
3. Checked both cards were working on my PC and they are fine.
4. Hooked up the computer and tried to access the card
5. Took the battery out and the filler piece that has to be removed for the big battery.
6. Had a good look around in side with the torch, and nothing seems wrong with it? Not that I know what i'm looking for
I had a stack on my birthday ride and thought that might have been the problem. But after getting the vid off the SD card I realised that the cam stopped well before the stacker on triple step. Also the camera starts and operates as per normal but doesn't show that a card is init. :cussing
Wondering if anyone else has had this problem, I couldn't find anything on the net about it. I rang Darren at Get On it Sports and still waiting for him to get back to me about getting it checked and fixed.
The cam has a symbol of an SD card in the corner with an X on it. When I press the record button it says no "SD Card" icon_scratch
Jono
WR450 '09
0421 182 790
Thu 08 Sep, 2011 1:35 pm
 Re: Drift Innovations - HD170 Stealth (SD Card not reading)
Darren just rang me! I have to try a few more things but if no luck, just post it back and he going to look at it for me. Get On It support is # ONE!!
Jono
WR450 '09
0421 182 790
Thu 08 Sep, 2011 2:21 pm
Post Re: Drift Innovations - HD170 Stealth (SD Card not reading)
have u locked it by any chance ? little tab on side of card..
Thu 08 Sep, 2011 3:28 pm
Have you tried formatting the card?
08 450x
Thu 08 Sep, 2011 6:09 pm
Same problem here.
Any ideas?
Wed 01 Feb, 2012 4:30 am
I had the same problem. It's come because a connector don't touch the sd card. I solve the problem simply with a knife.
Sat 18 Aug, 2012 10:18 pm
