View unanswered posts | View active topics It is currently Sat 16 Dec, 2017 11:33 am
Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 drift x170
Post drift x170
hi finally went for a decent ride to test out the cam it is great with the remote it works really well the screen is good to get a good angle but not much chop to view the video just to small. but I am having trouble with some settings it is like the cam can not adjust to the different light fast enough or something and even with the sound turned right down all you can hear is wind when doing some pace. The quality in this vid is not that flash as I stuffed up the settings in the editing program but if someone could give me some pointers that would be great.
You got the wine bottle cork stuck where??
Thu 17 Mar, 2011 5:41 pm
Post Re: drift x170
Nice Chad, I'm sure the Guru's will chime in soon enough and help out the niggling problems.
Keep posting your vids :headbang
Thu 17 Mar, 2011 5:49 pm
Post Re: drift x170
hey chad
first up can you upload a raw clip?
you can use avidemux to shorten it : http://fixounet.free.fr/avidemux/
just make sure you choose MP4 for the audio.
this will show the video as it comes from the cam
Thu 17 Mar, 2011 5:55 pm
Post Re: drift x170
now for the audio
you need a wind sock for the mic
its a basic foam over the mic that stops the wind from overpowering the audio (Like what is happening with yours).
Dags has tips on how to do this but its not hard I will see if I can get a link from jaycar for ya.
This is what sorted mine
also turn the mic down to the minimum as well (If you can??)
Thu 17 Mar, 2011 5:58 pm
Post Re: drift x170
to put a wind sock in you will have to pull the cam apart and cover the mic with a bit of foam and then reassemble. try it out and see if you need another level of foam.
one thing I found was that put the wind sock on mine (easy cause the mic i on the lead) and I taped over the top. over the mic and all. I did not expect it to work at all but it works fine!
In fact I think I need to go with 2 layers of foam and then tape.
perhaps you could just try some foam over the mic hole and tape over the top and then play with the level and see if you get decent sound?
its worth a try.
Its a known issue with these cams by the way!
Thu 17 Mar, 2011 6:07 pm
Post Re: drift x170
thanks simon that is what I was going to try do you have any idea about it chopping and changing with the light or is that just it trying to compensate for different light levels and there is nothing I can do.
Thu 17 Mar, 2011 6:20 pm
Post Re: drift x170
hey simon in that Avidemux after clicking on downloads what do i do then Im running windows xp so I go down to windows but witch do I click on next
thanks
Thu 17 Mar, 2011 6:25 pm
Post Re: drift x170
i think the light looks ok Chad ..but yer mic needs work , just tape it up..
how much was the camera>> ???
Thu 17 Mar, 2011 6:26 pm
Post Re: drift x170
viewtopic.php?f=95&t=2478
I just found the guide I did a while ago
Thu 17 Mar, 2011 6:28 pm
Post Re: drift x170
Under windows click the sourceforge link and it should promt you to download it
the install and follow the guide
post up any questions
Thu 17 Mar, 2011 6:32 pm
Post Re: drift x170
hey hori it did not cost to much under $200 free delivery from dags
thanks simon if I remember rightly we have been here before so thanks for helping my brain is like a sieve
Thu 17 Mar, 2011 6:41 pm
Post Re: drift x170
not a problem mate!!
Thu 17 Mar, 2011 6:57 pm
Post Re: drift x170
this one you can see what I mean about it changing light heaps, the water on the lens couldn't help
Sat 19 Mar, 2011 1:10 pm
Post Re: drift x170
hmmm
i just reseached and the x170 is only SD not HD. (I thought it was)
now it seems to me to be flicking light to dark without you going from light to dark....
coud be an issue with the cam.
what does it look like from the raw footage off the cam?? IE not uploaded on vimeo. I doubt its a vimeo issue though!!.
you could do an isolation test by going to a well liht room film a set picture or something and then watch the footage and see if the light changes the same way. IE no move ment and No light changes.
If you se no flicking of the light as in that vid then try movement round the room BUT make sure the light is constand and see if the light on the footage changes.
If those tests show changes in light levels like your vids then you have a problem with your cam.
1st best tip
Try a new better SD card
second new fresh batteries
third check for firmware updates
4th Dags.
Simon
Sat 19 Mar, 2011 2:04 pm
Post Re: drift x170
Chad I think the base x170 has a fairly basic exposure algorithim. In the overcast conditions the camera is "Hunting" for the right exposure nd you are getting the Light dark light dark issue.
The HD170 and the stealth (I Think) have the better proccessor and from reading the manuals they have the option of auto or manual exposure. maunal would solve this issue.
yours only has auto exposure.
I will PM Dags and see if there is a firmware update for these units.
The next thing is to wait (and wait and wait and wait) for a sunny day and then go for a ride and see how it goes.
BUT
two thngs again
GOOD SD CARDS kingston class 6 at least 10 is better.
These will get much more expensive soon as they are made in japan
decent batteries.
I dont think the above is the cause but worth trying
even with thos issue the vids look great so I would not get too stressed about it.
Sat 19 Mar, 2011 2:29 pm
