View unanswered posts | View active topics It is currently Sat 20 Jan, 2018 11:13 pm
Reply to topic  [ 14 posts ]
 motard rims
Post motard rims
i know this is more of a wanted but i though id post it here since its also motard related.
Question is what are the best (cheaper) motard style rims to get ,,, needed for a KTM 2011 model exc, car is being a bitch of late and im thinkin of a set of motard wheels just to do the run to work, its only 20 km away from home.
as far as set up with gearing i was going to leave the standard 13 front and run a 45 rear ease of only changing rear wheel set up.
also thinking of the brembo oversize upgrade kit..
any options are welcome......
Cheers,
Steve
Tue 23 Oct, 2012 6:33 pm
Post Re: motard rims
The cheapest wheels by far are the Torpedo7 wheels. The only problem is their stock varies, sometimes they have them, sometimes they don't. They are on sale at the moment for $599.99
http://www.torpedo7.com.au/products/T7W ... el-set-17-
Tue 23 Oct, 2012 9:18 pm
If you just want it to be a commuter I have a cheap pair of second hand sports touring tyres to fit those rims, I am chasing $80 for the pair;
http://www.ebay.com.au/itm/261117245365 ... 1555.l2649
Gearing will depend on what speed limit roads you use. I went for the smallest rear sprocket I could while retaining the stock length chain. You can use this website to calculate sprocket distances;
http://www.gearingcommander.com/
The stock dirt front disc will be perfectly fine for road use. If you start doing track days then I recommend a bigger disc. I went for a chinese $190 320mmm disc with caliper adaptor which just offsets the stock caliper.
You also need to think about the speedo. I have a trail tech vapor which lets me change the wheel size.
You will also want a supermoto front fender. $29 from third gear, they also do a TRA discount to make it cheaper again;
http://www.thirdgear.com.au/categories/Plastics/
Tue 23 Oct, 2012 9:28 pm
Wes. I take it , that blue bottle. Up front is your catch can ? You need this for lakeside ??
Tue 23 Oct, 2012 9:40 pm
Yes, that's my carby catch can for lakeside. Having a dodgy looking catch can is part of the supermoto look :)
The tyres in those photos are the ones I am trying to sell. The trackday bug has bitten and I coughed up nearly $500 on very sticky trackday focused road rubber instead :)
Tue 23 Oct, 2012 10:06 pm
I got a set of honda 250rr [mc19] wheels for mine..rear has a cush drive hub [bit less snatch on the g/box] $300 for the rims..approx $200 added bits bearings to suit different front axel size, rear sprocket..caliper adaptor as the std rotor is 320mm ..oh and i had to machine 20mm off the rear hub to get it all lined up..A real blast on the road.
cheap option is to get a set of road tyres to suit the std ktm rims..dont have to gin around with the speedo..most cruisers run 21" front tyres and the rear should have lots of options...
Wed 24 Oct, 2012 5:10 pm
Yeah but trying to get a decent sticky 21 inch front tyre isn,t easy BangHead
Wed 24 Oct, 2012 5:38 pm
Thats true..but if its only for a commuter then it would be heaps better than a knobby/universal...
Wed 24 Oct, 2012 5:43 pm
Yeah your right for the road they would be great icon_thumright
I was more talking about track days
Wed 24 Oct, 2012 5:56 pm
thanks for all the imput guys, i spyed thoes torpedo7 rims last night not bad for $600. im thinking i mite lean that way then i can get a decent set of tyres. Just the funds ATM .......... so if i upgrade the front disc i will have to adjust the speedo for that and also the wheel size.
Wed 24 Oct, 2012 7:17 pm
viewtopic.php?f=112&t=3924
Wed 24 Oct, 2012 7:23 pm
thats a good price laced up and ready to go...usually $1600 or more..
Wed 24 Oct, 2012 7:59 pm
If your tight on money then buy the torpedo 7 rims, put on some cheap 2nd hand tyres (like mine :) ) and just use your dirt discs for now. The front disc size has no impact on your speedo. Only the tyre size effects the speedo. Until you sort something out with the speedo you can get by with sticking a piece of paper to your handle bars that tells you what speed indicated is what speed actual. It's easy to calculate, just a ratio of the tyre rolling diameters.
I sold my DRZ speedo for $350 and bought a trail tech vapor with dash light kit for $165. The trail tech lets me adjust for wheel size.
Wed 24 Oct, 2012 10:11 pm
This thread has some info and more links on how to change the KTM speedo to work with 17" wheels.
http://www.supermotoaus.com/showthread.php?t=13201
Thu 25 Oct, 2012 8:06 am
