View unanswered posts | View active topics It is currently Sun 27 May, 2018 1:08 pm
Reply to topic  [ 5 posts ]
 400 to 450
Post 400 to 450
hey all I had some issues with my 400 .....yet again ............ well after having it rebuilt (top end) I went on the kenilworth ride last year 28th december....... awesome ride!!!!! go home and washed the bike, then took it on a dry off put and huge smoke clouds followed me ....... shane-o told me on the ride he could smell oil behind me. Well finally got it to a shop and the engine apart and the piston has overheated and expanded ..... scoring the piston , the bore and screwing the rings.
Anyways the time has come to fix it AGAIN ..... well talking with my "NEW" mechanic we were thinking since the 400 is a sleeved down 450,,,, can i replace the bore with the 450 sleeve and the piston to match or is more required.
any info will be welcome
I was thinking about turning the bike into a $7000 KTM boat anchor but the wife said that was not an option
Mon 18 Mar, 2013 5:13 pm
Post Re: 400 to 450
this what your after?
https://www.dicksracing.com/motorcycle_ ... g-bore_kit
2011 wr450f
98 yz250wr
Mon 18 Mar, 2013 5:25 pm
Post Re: 400 to 450
yeah, except its a 2011 not the old 400..... was wondering if you just replace the bore and the piston to get a 450 or does the bottom end or anything else need changing
Mon 18 Mar, 2013 5:57 pm
Post Re: 400 to 450
Think you just get the pisson and ring rebuilding kit for a 450 and bolt it on .probs
Ask at the ktm shop
Mon 18 Mar, 2013 7:51 pm
Post Re: 400 to 450
yeah i have to replace the bore because ti is that badly scored, so im thinking i can get the 450 bore and the 450 piston and ring set and should be good. il let you know what happens
Mon 18 Mar, 2013 8:31 pm
