View unanswered posts | View active topics It is currently Wed 21 Feb, 2018 1:24 am
andrew435 wrote:
1650bullet wrote:
if u find it is ur fuel pump i have replacement 1's for $99
Wed 04 Jan, 2012 2:56 pm
If you have any left, I will come and get one andrew" It will be good to keep a fuel pump in my camelpack for a spare.
Wed 04 Jan, 2012 3:20 pm
1650bullet wrote:
andrew435 wrote:
yeah mate they turned up the friday before christmas, have about 5 left
Wed 04 Jan, 2012 3:22 pm
dunno know don't care would never buy one again no matter how good the deal is.
Manager were did you buy that tow rope from will have to carry one now.
Wed 04 Jan, 2012 3:48 pm
whle i was on the side of the road i lifted the tank and disconnected the fuel clip to the injector and turned the ignition on and the fuel punp ran continuously till i turned off the ignition , maybe 5 to 8 seconds
Wed 04 Jan, 2012 4:23 pm
glad i didnt buy one :wav
2011 TM300
2013 exc300
Wed 04 Jan, 2012 4:33 pm
+100000000000000000000000000000000
00000000000000000000000000000000000000000000000
000000000000000000000000000.0
bootyshake
Wed 04 Jan, 2012 7:16 pm
Telecom, isn't that where all rope comes from. :D
Wed 04 Jan, 2012 8:27 pm
