View unanswered posts | View active topics It is currently Sun 18 Feb, 2018 6:47 pm
Reply to topic  [ 9 posts ]
 Broken case saver mount
Post Broken case saver mount
Hey guys. need some help with this little dilema. I picked up a stone in my chain last ride and only just noticed this damage when i went to put on a new case saver. Its pushed the chain forward and broken the mount for the top stud that holds the case saver on... Looking for some advice..
Can it be welded in place
does the motor have to come out.
does the motor have to come out and be split then welded up.
Chemi weld is out of the qustion. i dont want to dodge this one up. it will get fixed properly....
I heard freaky is the master welder.... Any thoughts...
Sat 05 Mar, 2011 3:22 pm
Post Re: Broken case saver mount
http://www.facebook.com/#!/photo.php?fbid=10150157989340610&set=a.105096250609.123982.632650609&theater
http://www.facebook.com/#!/photo.php?fbid=10150157990055610&set=a.105096250609.123982.632650609&theater
Sat 05 Mar, 2011 3:29 pm
no idea post pics straight on here
Sat 05 Mar, 2011 3:37 pm
here r those pics.. motor wont have to come out i wouldnt think..
200653_10150157989340610_632650609_8784633_8041934_n.jpg [ 59.85 KiB | Viewed 2070 times ]
196673_10150157990055610_632650609_8784638_538835_n.jpg [ 58.21 KiB | Viewed 2070 times ]
Sat 05 Mar, 2011 3:39 pm
Jack88 {Paul} did great job on mine simular situation ..
Sat 05 Mar, 2011 3:41 pm
Looks ok need a little further away shot,but yer just take bike to any ally welder,weld or tig up re-tap a thread all good
Break looks pretty dirty say maybe its been cracked for a little while
Sat 05 Mar, 2011 5:47 pm
Yeh on the piece that broke out it is dark on one side and a fresh crack on the other. Thanks.
Sat 05 Mar, 2011 6:29 pm
Id say your bolt was too long and when tighting it up you've bottomed it out and pulled / cracked it away.
as dale said. weld and re-tap it. easy!
Sat 05 Mar, 2011 8:20 pm
I thought so maybe too but there is 4mm clearance on the bottom of the thread
Sat 05 Mar, 2011 8:32 pm
