View unanswered posts | View active topics It is currently Wed 17 Jan, 2018 1:23 am
Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Berg Fe350 2013 using oil
Post Berg Fe350 2013 using oil
Hello everyone, I'm new to the site and need some assistance. My 2013 Fe350 seems to be using oil and the dealer says its fine. Done 1200klm and owned since new. Have done regular oil and filter changes every 200-300klm. Added aprox 300ml and done 280odd k's since then. About to do another change and sitting in the window but about 1/3 from the top of the window. Riders behind say its blowing smoke. IDEAS?
everywhere you look, there you are!
Thu 27 Mar, 2014 1:27 pm
Post Re: Berg Fe350 2013 using oil
Welcome and not much of an idea but i would be telling the person at the bike shop to stick in his arse.
Thu 27 Mar, 2014 3:56 pm
is it blowing smoke all the time??? or just when its been on its side or been flipped cus it could just be burning the miss placed oil . if its doing on a easy ride now lay downs , then its sounds its due for a top end rebuild
Thu 27 Mar, 2014 5:41 pm
Thanks Shaun that's what I reccon.. last couple of rides have been uneventful because a mate hurt his knee and not going hard. I think its using about 100ml per hundred K. No power loss and I am 46 so no big times monos or over the top riding. Just a hack that loves a blip.
I did do air filters and caked the oil on... shop said its sucking oil from the inside of the filter, I said that crap but all tests came up good.
Just over 20 hours on the cockpit recorder.... manual says 100h before rebuild.. I'm confused.
Thu 27 Mar, 2014 6:11 pm
pfft sucking oil from the filter is BS.
id say you have piston ring issues if it's using oil or even blowby,
i use about 200mm of oil with a bad sprocket leak pissing oil every where over 100km
so your oil is going somewhere, if it's not on the ground then it's internal
Thu 27 Mar, 2014 6:19 pm
What oil do you use?
Thu 27 Mar, 2014 7:35 pm
Gavin 350 mad wrote:
Thanks Shaun that's what reccon.. last couple of rides have been uneventful because a mate hurt his knee and not going hard. I think its using about 100ml per hundred K. No power loss and I am 46 so no big times monos or over the top riding. Just a hack that loves a blip.
I have got the 2013 450 berg done 200.hrs no problems .. Maybe you might have sucked some dust down
Thu 27 Mar, 2014 9:02 pm
I presume you put in the correct amount of oil?
Fri 28 Mar, 2014 8:12 am
Using Motorex 10w 60 Fully Synthetic and yes using the correct amount... I agree with everyone, to me its internal.
Fri 28 Mar, 2014 8:42 am
Firstly, using 100ml of engine oil per 100km of riding is not normal.
So to get this straight, you added 300ml's of oil, rode 280km's and it used oil, now the oil is 1/3 down form the top of the sight glass?
So where was the oil level when you first added the 300ml of oil? Right to the top of the slight glass?
Suspension Matters
www.suspensionmatters.com.au
Ph. 041-REVALVE
Tue 01 Apr, 2014 2:28 pm
How much oil are you putting in for each service?
Are you measuring it when it comes out?
Tue 01 Apr, 2014 4:07 pm
I suppose most bikes will do a little oil in a ride , heat and friction ,
Shaneo's not fixed that oil seal yet ?
Tue 01 Apr, 2014 5:31 pm
na i cbf fixing it. it's only a sproket seal :P ill wait till the front sproket wears out lol!
Tue 01 Apr, 2014 6:07 pm
Ok Mr I'm to busy to spend time on bike lol
told u 6 months ago was just that seal
Tue 01 Apr, 2014 6:31 pm
wasnt the seal at the point hori.
its just a old seal now.
Tue 01 Apr, 2014 6:33 pm
