View unanswered posts | View active topics It is currently Sat 21 Oct, 2017 4:40 pm
 Friday the 13th
Post Friday the 13th
Organised to go around to a mates place to try and heat up and blow out the dents on the expansion chamber
1.Take off the expansion chamber,easy.
2.Take around to mates place,easy.
3.Find some thing to block off the ends of pipe,getting harder.
4.Steves mate comes around,we have a cup of tea while his mate shows us some photos
5a.Go back to shed,cant find some thing easy to plug ends so turn some wood on the lathe.
5b.Some thing goes wrong with lathe,attempt to fix problem about four times.
6.Drill hole for valve in end of wood and glue in with good glue.
7.While glue is going off go and have lunch.
8.Get back and continue with project.
9.Knock into the ends the pieces of wood and tie-wire them in for safety.
10.Pump up to 20psi like in the video i saw,leaking through the grain in the wood.
11.Only one end is doing the number 10. thing.Take out and proceed to make air-tight,four times this happend.
12.Air-tight ye-ha
13. Put 20psi in and heat up the biggest dent and get glowing red,a bit more pressure.
14.Dent is comming out,its working.
15.A bit more air.
16.Ka-boom,the big plug blows out at a million miles an hour and goes between my chest and under my arm,hits the wall and bounces and lands on the shed floor.
17.While number 16. is happening Wayne is doing a number 2.uncontrollabley.
!8.After a while swearing my head off and chit-chatting we finish up and i go home.
19.Not over yet,walk out to car and ive locked the keys in the car.
20.Had some spare keys in the back of ute,whent
Next Friday the13th im renting some dvds on Thursday,stocking the fridge with supplys and not going out of the house
Fri 13 Jul, 2012 6:41 pm
Post Re: Friday the 13th
go have a beer drunken_smilie
Fri 13 Jul, 2012 9:27 pm
Was Shelly's birthday all went good for her here :P
she was born on friday 13th 2001 also , and had another birthday on friday 13th back in 07 i think..
i just think ur silly Wayne not tying the end off the cap u put o the pipe with wire ,
hope ur ok
Sat 14 Jul, 2012 5:06 pm
hope ur ok
Dont worry i did ti-wire the ends on,still blew off.
Sun 15 Jul, 2012 6:20 am
yes but u didnt tie off properly then , otherwisw wouldnt of missiled at u
Sun 15 Jul, 2012 6:49 am
It just broke the wire,should have used 8 gauge wire
Sun 15 Jul, 2012 7:23 am
An less psi ..around 15 psi is whati have read..
Sun 15 Jul, 2012 9:31 am
And yes less but got impatient
Sun 15 Jul, 2012 9:38 am
