View unanswered posts | View active topics It is currently Tue 23 Jan, 2018 10:12 am
 break light problem
Post break light problem
ive got a problem with my front n rear breaks not making the break light work. i cna put 12v to the led light and it works. and i got ohms at the break wires like i put the multimeter across the two wires and it showes there a conection there. but stil lthe light aint wroking
ideas please
Tue 22 Sep, 2009 5:29 pm
Post Re: break light problem
director what you need a brickie to come change a light bulb for ya :lol: :lol:
Tue 22 Sep, 2009 5:34 pm
are all fuses OK?
you should have an open circuit when no brakes applied ie: lots and lots of Ohms
when either is pressed you should have a virtual short, ie no or very little ohms
do you have continuity to the brake light?
are all other lights/indicators OK? check earth/ground to the frame
there's a start for you
Chris
07 DR650, TRA's bad copy of "QWERTY"
Tue 22 Sep, 2009 6:46 pm
fix a bike ?? you couldnt put a nut in a monkeys mouth ! :lol:
Tue 22 Sep, 2009 8:15 pm
not a bulb problem i have the awesome led break lite... unlike then old out of date bulbs.....
ill have more of a play with it tomorrow ive been reading the manual on where every thing is hehe
Tue 22 Sep, 2009 9:20 pm
Dont think you can swap out a bulb type for an LED light mate without modification.
Has the light worked before. IE was it going then it broke or is it a new setup
Tue 22 Sep, 2009 9:23 pm
all sorted. didgy wire had two strands left. just under the rear guard. :S too much roost!
Wed 23 Sep, 2009 2:19 pm
