View unanswered posts | View active topics It is currently Fri 23 Feb, 2018 8:28 am
 Can I use 19inch back wheel? Ktm 525
Post Can I use 19inch back wheel? Ktm 525
As above guys found some wheels for $400 but they are sx wheels having a 19 inch back wheel, will this make any difference for trail riding??? Thanks in advance
www.dentremovalbrisbane.com.au
Paintless dent repair
Sun 05 May, 2013 8:44 am
Post Re: Can I use 19inch back wheel? Ktm 525
Only Difference i can think of is tyre choice and will slightly raise you rear by half a inch.
Sun 05 May, 2013 9:28 am
Yes you can use a 19 inch back wheel, but...
You will have less choice when it comes to trail riding type tyres, as they really only make MX tyres in 19 inch. A 19 rear tyre does not absorb bumps as well as an 18 so it wont be as comfortable, wont hook up as well over rough ground and you will get more punctures.
Try to stick to an 18 inch if you can.
Suspension Matters
www.suspensionmatters.com.au
Ph. 041-REVALVE
Sun 05 May, 2013 9:30 am
Thanks freak and suspension matters, he said he would take 300 for them so they will do as a spare set but I will take your advise, much appreciated, I will get a 18inch wheel to match and get some road tyres for the others.. Once again thanks guys for fast response. icon_thumright
Sun 05 May, 2013 8:34 pm
At $300 it sounds like good buying.
So one option is to buy an 18 inch rim and spoke kit and get it laced onto your new hub. Depending on the quality of rim and spokes you buy, this will cost you about $300ish.
Suspension Matters
Ph. 041-REVALVE
Mon 06 May, 2013 8:12 am
Sounds like a plan!! Who do you recommend for wheel rebuilds? Cheers guys
Mon 06 May, 2013 6:44 pm
Users browsing this forum: Majestic-12 [Bot] and 1 guest
