View unanswered posts | View active topics It is currently Tue 20 Feb, 2018 7:52 pm
Reply to topic  [ 11 posts ]
 I need an auxiliary fuel tank/bag rack to fit a 2009 WR450F
Post I need an auxiliary fuel tank/bag rack to fit a 2009 WR450F
I'm after one of those fuel tanks which slips over the rear guard for a trip out to the coast. My trip will be this: Cowra to Boorowa (first fuel stop - 76.5kms), then from Boorowa to Yass (around 50kms), then from Yass to Goulburn (just under 90kms), then from Goulburn to Bowral (around 70kms although there's a petrol station about halfway at a place called Marulan). From Bowral I'm pretty certain I can make it down to Nowra no problem, and then from there it's only a short ride to Huskisson where I'll be staying.
Basically I've got to cover about 80kms to get to the first fuel stop - I have no idea how much I get out of the standard tank...But I am able to commute to work and get home on a single tank and that's about 60km all up. There's a little bit left in the bottom when I get home...
Does anybody know what the range of the stock tank is? If it's not enough to make 80kms, would the Acerbis 2.1 litre tank in addition to the standard tank be enough to make it that far?
I also wouldn't mind getting a rack to put a bag on or an esky for when I ride to work - what kind of rack can I get that will fit an '09 WR450?
Ed
Wed 28 Nov, 2012 6:44 pm
Post Re: I need an auxiliary fuel tank/bag rack to fit a 2009 WR4
Have you considered a clark 13.5 litre tank from ballards (from memory i think i got around 140 to 150 k"s little while ago now) dontknow you"ll have plenty of room for a rack then mmmmmm rack hello2
Wed 28 Nov, 2012 6:51 pm
I have a 13.5 tank for my wr 05 model,that I'm selling not Shore the difference in the models,I'll have to check??
The faster I go the harder I fall
Wed 28 Nov, 2012 7:23 pm
Is the Clark one a replacement for the main tank or is it an extra?
Wed 28 Nov, 2012 7:42 pm
Replacement one,you will be stuffed before you run out of fuel,
Wed 28 Nov, 2012 7:45 pm
the clarke tank is a replacement tank. Easy to swap over. The only issue would be the fuel tap which if you use the standard tap will end up on the underside of the tank. Still easy to get to but on the inside. Check Ballards, i think they are having a 50% off on clarke tanks at the moment. If not order from Just tanks in USA. All up delivered is still cheaper than buying here. Hope this helps
Wed 28 Nov, 2012 7:50 pm
The tanks are universal,the acerbic one I have SORRY, you get an out let with it,and you have two,I use one for the bike the other to refuel others when needed,HUSKY riders crybaby2 crybaby2 with an extra long hose.
Wed 28 Nov, 2012 8:00 pm
Ballards only do WRF tanks for 03-06 models.
Why does nobody do the more modern bikes?!
Wed 28 Nov, 2012 8:01 pm
This is what I had in mind originally -
http://thumbs4.ebaystatic.com/d/l225/m/ ... 6Y3_wA.jpg
Just found one on SafariTanks.com.au - Anybody have any experience with these?
Wed 28 Nov, 2012 8:07 pm
go searching here
http://justgastanks.com/index.php?cPath=4
Wed 28 Nov, 2012 9:10 pm
http://justgastanks.com/index.php?cPath=4_42_59
Wed 28 Nov, 2012 9:11 pm
