View unanswered posts | View active topics It is currently Fri 20 Oct, 2017 9:50 am
Reply to topic  [ 13 posts ]
 Brake pad wear
Post Brake pad wear
Just pulled the front brake pads out - first time I have done this since buying the bike, had a look from time to time, but never pulled them out.
Is there any particular reason why the one on the piston side has worn down so unevenly and the one on the other side is fine?
Is my caliper no good somehow?
Cheers, Dave.
Tue 26 Jun, 2012 5:14 pm
Post Re: Brake pad wear
the caliper slides are seized or not sliding freely
bolt your caliper on your bike without the pads can you move the caliper in and out it should slide towards the rim and away if not your slides are seized crybaby2 this can be a pain to fix if left too long
Tue 26 Jun, 2012 5:21 pm
Cheers. Just checked, slides fairly freely but a bit stiff maybe. How freely are they supposed to move??
There are rubber boots over the shafts, one of them is broken, might have let a bit of crud in.
Tue 26 Jun, 2012 5:38 pm
yeah i cant seem to wear a set of fronts out , yet i use em alot ..
Tue 26 Jun, 2012 5:44 pm
Normal if you ride beerwah alot,
I seam to do this to front pads also and I allways service and clean my calipers out,
Tue 26 Jun, 2012 5:58 pm
pull the caliper right off the bracket buff the pins or hit them with the wire brush, spray heaps of cheap wd spray in the holes to get the gunk out, if the pins are worn they can cause the caliper to stick , lube with lithium grease, these slides fill up with poo all the time and are usually negletcted by most of us , should slide quite smooth with an even resistance no tight spots icon_thumright
Tue 26 Jun, 2012 6:00 pm
... Are both pistons supposed to move? dontknow
No pressure on the pad from the top one, bottom has heaps of pressure...
Piston side pad is also more worn on the bottom than the top, would that be from the top piston not putting any pressure on the pad?
What would cause one piston to not move??
Thanks for the replies people, everything I pull apart on the bike is a first for me - never been very mechanically minded, but trying to learn all I can.
Cheers.
Tue 26 Jun, 2012 6:24 pm
ok so get two small g clamps from the hardware store use one to hold the good piston in, then slowly press the front brake untill the other piston moves but not so much that it comes out completely about 5mm will be safe now use g clamp2 to wind piston back in, repeat a few times until it moves free . if you cannot move the piston with the brake lever and g clamp on good piston then it's caliper rebuild time!
good luck :D
Tue 26 Jun, 2012 6:31 pm
Cheers, will try tomorrow. icon_thumright
Tue 26 Jun, 2012 6:37 pm
When you push the pistons out rub some rubber grease or lanolin grease around the sides of the piston,just a smear mind you.Then push back in.
Tue 26 Jun, 2012 8:36 pm
Although Im not the OP, thanks all that have posted, have just learnt a lot as its brake pad time for the WR - any brands of pads better etc?
Sun 15 Jul, 2012 8:29 pm
yep buy sintered pads
Sun 15 Jul, 2012 9:51 pm
I remember when Shane told me to put air hose on caliper to blow out piston shah it shot out alright.. right into his ankle lol
Mon 16 Jul, 2012 10:05 am
