View unanswered posts | View active topics It is currently Mon 18 Jun, 2018 10:07 am
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 COMPUTER QUESTION?
Post Re: COMPUTER QUESTION?
Hori wrote:
all computers have beep codes on bootup..
cpu test OK
Mem Test OK
just hit tab key on bootup n u will see bootup menu more clearly..
But why is it making the noise now....it has never made this type of noise before....makes me think the shop have replaced something and just told me it was dust....and double dipped crybaby2
a holes
________________________________
05 CRF450X......
97 XR400R
94 XR250R
92 ZZR250
Mon 04 Jul, 2011 8:23 pm
They could have just enabled the beeps in the bios.
next time PM me or Hori and we will help Free of charge.
Happy to help. (perhaps a beer or three). If you have your original docket and the computer we should be able to tell if they have swapped something.
But if the puter did not beep before but beeps now its likely they turned the bbeps on for diagnostics and left them on.
what shop?
Mon 04 Jul, 2011 9:08 pm
TEXASRANGER wrote:
cpu test OK
Mem Test OK
a holes
When a computer starts is does a series of POST (power on self test) tests. As Hori said it checks memory, cpu, main board etc etc. If all is good it will make one single beep when finished and then load the computers BIOS then start the operating system. If it does a series of beeps then there's a fault. The number of beep codes is then determined to what part of the hardware the fault related to. These beep codes are in relation to the BIOS on the system board. If no beeps at all chances are the main board if fugged.
Is it just a single beep now ?
Did it make that single beep before ?
If it makes it now but not before chances are the internal speaker may not have been connected and they have now connected it correctly. If that's the case then now need to worry.
Mon 04 Jul, 2011 9:14 pm
Oh and if that doesn't work send me your credit card details and all associated pin numbers and I'll see what I can do... evil6 evil6 evil6
Mon 04 Jul, 2011 9:18 pm
what shop?
what you are saying sounds like what has happened Simon....I think you are on the money.
yeah Computer Function at Indorripilly.....
05 CRF450X......
97 XR400R
94 XR250R
92 ZZR250
Tue 05 Jul, 2011 7:39 am
Legend
I have never seen an option for enabling/disabling beep codes in the bios
of any Award, AMI or Phoenix Bios.
As Frank said, I wouldn't mind betting that the internal speaker
wasn't hooked up to the front panel header.
If it works fine and doesn't hang on boot,
I wouldn't worry about any single beep.
It's when it makes a series of beeps
and repeats them in an endless loop
that you have problems.
BTW, Mine makes a single beep as it passes POST.
John - KLX680R * Let the good times roll
Tue 05 Jul, 2011 3:21 pm
my last lot of overclocking motherboards has had digital code display on the motherboard also .. also had reboot switch on motherboard to make overcloking easier from a bench..
But Bathy is right i cant remember disable enable option of beep codes , but maybe disable enable boot screen on startup.. in which if it's mem will hang on mem quick scan .. or cpu sho cpu malfunction error ..
Tue 05 Jul, 2011 4:20 pm
