View unanswered posts | View active topics It is currently Fri 19 Jan, 2018 5:46 pm
Reply to topic  [ 10 posts ]
 rm 250 06 - 08 mains
Post rm 250 06 - 08 mains
looking for exp mechanic to rebuild split cases and reassemble my rm250 06 motor and replace mains bearings. ( ive got the service manual as well ) prefere gold coast / brisbane area?
#1 - first I drained gerabox oil -
dirty but no metal and nothing on the magnet.
it only just started binding up yesterday - not seized.
#2 ive taken barrell piston off checked = perfect ok
crank feels good so its not big end.
clutch taken off = perfect as well.
I can still feel binding on and off as the motor is turned by hand.
Feels like one of the mains has run and now i see some small metal fragments are in the 2 stroke oil at the bottom of the motor when the crank dips into it. very minor.
ive ordered the complete engine gasket set and a set of hot rod mains bearings kit with seals.
ill take the motor out - any suggestions RE-expected $ costs to just split check and reassemble. I could probably do it myself but im not really that experienced with gearboxes and cranks and pressing bearings in and out of cases.
Cash$ :headbang Eric 0410817455
300cc of yehaaaa!
Sun 18 Oct, 2015 12:30 pm
Post Re: rm 250 06 - 08 mains
Andrew 435 has shop ..
But im sure no $$ at completion no pickup engine .
He been stung before ..
But has re built my 450 bottom end and gearbox and tm top ends
Top job ..
Sun 18 Oct, 2015 3:47 pm
Ok mate this is confusing ..
Rm or rmz ??
Rm gearbox nothing to do with crank..
You mention crank dipping into 2 stroke oil ???
More info please !!
BB
Sun 18 Oct, 2015 10:30 pm
u being picky me thinks
#1 id never own a 4 stroke dirtbike again!
#2 in all 2 strokes oil builds up in the bottom of the crank and pools so the big end dips in.
#3 if one mentions 2 troke oil in the txt its cause its a 2 stroke?????
#4 just saying is not the gearbox nipping up if the oil is clean -proved it now = def mains
#5 RMZ is not an RM no where have i mentiond RMZ
#6 And if your not going to be helpful keep your picky suggestions to your self and stick to revving up hori.
300cc of yehaaaa!
Mon 19 Oct, 2015 12:28 pm
Well said viking
Bb just father mechanic
Go see Andrew
Mon 19 Oct, 2015 4:39 pm
Not picking on you at all mate ..
Just clarifying things ?
Cause on a 2 stroke oil doesn't pool in the crank ,
I was going to say I could help you for free and the money you save would be best spent in a new crank while it was apart .
icon_scratch icon_scratch
Mon 19 Oct, 2015 5:37 pm
Also you could slip the primary gear off jus to have a batter feel of the mains .
Mon 19 Oct, 2015 5:39 pm
I did exactly that - confirmed its the main bearing nipping up!
And thanks for the input.
300cc of yehaaaa!
Mon 19 Oct, 2015 7:39 pm
If oil doesn't pool in the crankcase how does the mains and big end get lubrication icon_scratch why put a new crank in it when you can just replace the rod dontknow
Good idea take it to him
Tue 20 Oct, 2015 6:01 am
My oil pooks in my Crankcase waiting for Freak all the time !!!!!
Wed 21 Oct, 2015 4:30 pm
