View unanswered posts | View active topics It is currently Fri 20 Oct, 2017 2:28 am
Reply to topic  [ 9 posts ]
 starter motor
Post starter motor
over the last few months I think my starter motor has been misbehaving it would engage the act like its out of battery then would go again . now it has stopped altogether there is power to the switch all fuses are good is there a way to chec it without removing it from the bike
Tue 07 May, 2013 9:23 am
Post Re: starter motor
Have you cleaned the starter button. If not Squirt a good amount of WD-40 up threw the button, and then use compressed air and blow it all out high and dry. Mine done it once and that was the problem. Moisture gets in there all the time.
P-s. Have you tried the good old hammer treatment and give the starter motor a tap here and there.
Tue 07 May, 2013 10:15 am
Sounds like your brushes are worn out
Tue 07 May, 2013 12:10 pm
OK CLEANED ALL START BUTTON TERMINALS AND HAVE POWER ONCE BUTTON IS ENGAGED (TEST LIGHT SAYS SO)
REPLACED STARTER RELAY AND CHECKED ALL FUSES
I CAN WIND THE STARTER MOTOR OVER AND START THE BIKE BY SHORTING OUT THE RELAY
EVERYTHING SEEMS TO WORK BUT I STILL CANT START OR GET ANY REACTION BY JUST PUSHING THE BUTTON.
WHAT NEXT
Wed 15 May, 2013 6:20 pm
starter solenoid farkked ;)
Wed 15 May, 2013 6:37 pm
Where is the starter solenoid located
Wed 15 May, 2013 7:53 pm
should be beside battery or around that area .
Wed 15 May, 2013 8:11 pm
hm thats funny my cousin (justo) has a 2013 ktm 300 and he has replaced 3 buttons on that fking piece of sh*t and now power wont run to the starter motor at all and ktm wont do anything about it crybaby2
2011 TM300
2013 exc300
Thu 16 May, 2013 7:58 pm
Muffler side in the air-box area.
Should look like the pic below. Check the fuse and clean the connection. Make sure everything isnt loose.
Fri 17 May, 2013 6:03 am
